Not able to view records in Interaction History but able to view records in IH Summary
When I run the data set pxInteractionHistory, I am not able to see any records. However, when I run the pyIHsummary data set, I am able to see the records.
@KuntalS6 Starting from the 8.8 release, the IH records are stored in a file rather than in the RDBMS table (as long as the file repository location is configured correctly). The pxInteractionHistory reads data from the table and does not read from the file hence you see no records. This is the default configuration for any new implementations starting the 8.8 release. Client upgrading to 8.8 from a lower version will continue to store data in the RDBMS table unless it is explicitly configured to be saved to files.
Please read the following documentation.
