Session persistence on azure load balancer
Do we need session persistence to be enabled ON in the azure load balancer settings for Pega applications ?
Siva
@SayantanC3655 @Sivaraman
did you already go through the documented Setting up load balancers ?
Pega Platform requires session-based affinity support in a load balancer to ensure that requests from one user are directed to a specific application server that maintains the state for that user. It is a Pega best practice to use cookie-based session affinity. Therefore, the "None (hash-based)" option in Azure load balancer, which provides stickiness only within a transport session, may not be suitable for Pega applications as it does not maintain user session affinity across multiple requests.
Pega 7.2.2 session gets automatically logged off after login
Cookie usage in Pega software > Pega Cloud – High Availability
Balancing HTTP traffic across multiple server nodes
Authentication > Session management
