Du
Du
AE
Du
Posted: Dec 12, 2023
Last activity: Jan 9, 2024
Last activity: 9 Jan 2024 8:49 EST
embeded hazelcast vs external hazelcast
when we should consider to use external hazelcast instead of embeded hazelcast for pega cluster? is the Max number of nodes threshold above which we must move to external hazelcast?
Asad
***Edited by Moderator Rupashree to add Capability tags***
@SyedAsadAliS16632931
You should consider preparing your application for exernalized hazelcast.
It will certainly be mandatory once. It's already more than highly recommended.
Embedded version was the default and it will indeed use some resources and hazelcast as such can have its own issues.
Embedded or not, it's a component which can create some troubles or which can be troubled.
Regards
Anthony
