Cognizant
Last activity: 30 Aug 2023 23:39 EDT
ORA-14402: updating partition key column would cause a partition change
Hi Team,
I'm getting error message"ORA-14402: updating partition key column would cause a partition change" while approving a request in the workbasket. As part of the code we are not updating any partition column, but in the background a merge query is auto generating and trying to update the partition column. Due to this error, unable to approve the requests. Please share your thoughts...
Error Message: [MSG][Error in commit()][STACK][com.pega.pegarules.pub.database.DatabaseException: ORA-14402: updating partition key column would cause a partition change DatabaseException caused by prior exception: java.sql.BatchUpdateException: ORA-14402: updating partition key column would cause a partition change | SQL Code: 14402 | SQL State: 72000 DatabaseException caused by prior exception: java.sql.SQLException: ORA-14402: updating partition key column would cause a partition change | SQL Code: 14402 | SQL State: 72000 : SQL: MERGE INTO DATA.pc_assign_workbasket
@Ravi prasad The error message "ORA-14402: updating partition key column would cause a partition change" occurs when an attempt is made to update a partition key column in a way that would cause the row to move to a different partition. In your case, it seems that a MERGE query is auto-generated in the background and trying to update the partition column.
To resolve this issue, you can try the following steps:
This answer came from a Pega gen-AI assistant using the below references. As a Support Center moderator, I reviewed the answer and references for accuracy:
Update fails with ORA-01451, ORA-02429, and ORA-02443 [SDR-301] > Sympto
Adding partition to database
Troubleshooting ORA-02443, ORA-02429, ORA-06512, Oracle optimization issues
If the issue persists, you may need to contact Pega Support for further assistance.
Please provide the INC reference here if you do log a ticket.
