Rulesstack Solutions LTD
Last activity: 23 Aug 2023 9:38 EDT
Switch application gadget/ menu item on Pega Constellation
when the operator has access to more than one application, user is able to switch from existing application(Pega UI kit) to constellation application but not vice versa.
Any ideas on how to add switch application to operator menu in Pega constellation above log off .
we are using Pega 8.8.2
@SamarendraR7059 In Pega Platform 8.8.2, you can switch between applications using the "My Applications" gadget in App Studio or the "Application" menu in Dev Studio. However, if you want to add the "Switch Application" option to the operator menu in Pega Constellation, you would need to customize the menu by modifying the relevant rules and components. Please note that customizing the menu might require advanced knowledge of Pega Platform and its components.
This answer came from a Pega gen-AI assistant using the below references. As a Support Center moderator, I reviewed the answer and references for accuracy:
Switching between applications in Dev Studio
Enabling Constellation for an application
