Report definition - return null value
Here, When the case status= Resolved-Completed, this Vehicle Current Value should be Null. How I do this one ?
Please provide your valuable input
***Edited by Moderator Marije to change type from Pega Academy to Product***
@KasunS98 Hello
You can apply the function on 'Vehicle Current Value' column as below
Note: This will not update your case data, If you want to update your case data as well, then you need to nullify it before resolving the case in post actions.
