data integrations
what happend in rest connector when there is a change in service provider?.we have to change our end?
***Edited by Moderator Marije to change type from Pega Academy to Product***
Hi @Motukatla: From the above response I could get that the service provider is changed from one system to another and there is change in the service architecture too. Said that this is a new systemwith different architecture, you may need to create new integration in PEGA. Based on your application standard architecture for interfaces, you may need to create new class structure / you may can extend the existing.
If you have proper data layer configured to the interface and if you are using data pages to access the interface, then you can add when condition to your existing data page and can add new connector in the source based on condition (or) you can replace the connector defined in data page. In this way only the integration layer will be changed and can reduce the impact to the data layer.
Thanks.
@Motukatla yes we have to change from our end.
If endpoint URL, DSS. If authentication change, authentication profile.
@Anoop Krishna service end response parameters changed.their is no change in end point url
Thanks.
