IBM
CN
Last activity: 21 Dec 2022 21:41 EST
Dynamic layout: Alignment or Float
Hi, could you kindly help?
I found below setting of a Dynamic layout (Alignment : Auto) will show good display effect.
But, in Dynamic layout of another section, the setting is "Float", and it is not in good display.
May I know how to change the setting same as above, Alignment? Thanks.
Hi @MaxonL16591286: Can you explain more about what is mentioned as good display effect and not good in display.
Generally parent dynamic layout will have the option of float and the sub layout will have the option of alignment.
Also please check: https://docs-previous.pega.com/sites/default/files/help_v73/rule-/rule-html-/common/basiclayoutpresentationtab.htm for details.
Thanks.
