Customize table filter "Search Text" field label to use column header
Hi All
Is there a way to access the table column header as a parameter and replace the "text" in the default "Search Text"
so it will be something like "Search First Name" instead of "Search Text"
This is the OOTB rule that contains the Search text field section "pyGridFilterRangeFields"
@DavidJ09 Hi
If you open up the cell properties, there is an area to customize the label value. I would then able a when condition for the circumstance you were intended on using it with. Let me know if that was helpful
