Infosys
Last activity: 31 Aug 2020 13:49 EDT
Is Pega Robot Manager compatible with other than pega cloud?
I am confused whether Pega Robot Manager can be installed on other cloud other than pega.
can we make the pega robot manager, to utilize the organization existing database (SQL Server, Oracle ) which is currently the organization/team using?!
Does Pega Robot Manager requires any prerequisite like installing database priorly?!
Thanks in advance
Best Regards,
Sai Santhosh Kumar Batchu
***Edited by Moderator Marissa to update General to Product***
Pega Robot Manager is an application that you install within your Pega instance. The pre-req is that you have the appropriate Pega version (corresponding to the Robot Manager version) installed already. It would be using that Pega database. It is not a standalone product outside of the base Pega Platform and is expected to be installed within an existing Pega Platform.
