Bits In Glass
Bits In Glass
Bits In Glass
Posted: Dec 31, 2019
Last activity: Dec 31, 2019
Last activity: 31 Dec 2019 9:53 EST
Hai guys, I met with an error while building android mobile app. Build Failed( check the logs for details). How can I overcome from that error?
Check these links which talks about common errors encountered while building an app. See if those apply to you. If not, please post the error you notice in the logs.
https://community.pega.com/video-library/common-issues-encountered-while-building-mobile-apps
https://community.pega.com/support/support-articles/error-mobile-app-build
Please share the logs from the same time frame, or the error stack logged.
Thank you,
Pawan
