Northwest Missouri State University
Posted: Sep 30, 2019
Last activity: Oct 1, 2019
Last activity: 1 Oct 2019 2:56 EDT
trying to Hide case creation for an access group
Hi all,
I am trying to hide a case creation for 1 set of access group. Is there any configuration which can be done at the case type Level, rather than writing when rules or privileges?
In the starting process pyStartCase of the case type, under the "Process" tab you can add privilege. If this Privilege is not added in the the user's Access role, they wont be able to see the case type in the Create menu. I think this is the straight forward way to achieve the requirement.
Let's see if any PSC member has more simple solution. Thanks
