How to make stop refreshing/reloading data pages by Agents
In our application(7.1) in every stage change, we are generating xml files with case information and send to the reporting team. There is a one scenario where the agent is processing the case and change the case stage. In this particular scenario we lose some of the information from the xml.
After analyzing, identified that this particular information is fetched from a data page and at the time of agent processing it references a different or an empty data page context. To avoid this we have used inBatchRequestor when condition in Do not reload when field but, still this approach not works.
Any other ideas how to resolve this?
Configurations:
Configurations:
What are you checking in the when condition?
You can try the below approach.Before calling the datapage in the activity,set a flag and in the datapage write the do not reload when based on the flag.After the datapage is referred,in the next step reset the flag so that the datapage will be reloaded if it is called from any other rule.
