Certificate issue with GlobalSign - Pega CustomerService Healthcare 7.4
Hello! I have installed the latest and greatest - Pega 7.4 and the Pega Customer Service for Healthcare 7.4 framework. I can run the Interaction Portal. I did a Change PCP and the search failed. In the log file, I am getting an error on the Certificate - java.security.cert.CertPathValidatorException: The certificate issued by CN=GlobalSign, O=GlobalSign, OU=GlobalSign Root CA - R2 is not trusted; internal cause is: java.security.cert.CertPathValidatorException: Certificate chaining error.
My question - where do I get the GlobalSign certificate to add to my environment? The right certificate should resolve the issue.
Thanks!
Certificate Authorities publish their certificates on the internet:
https://www.globalsign.com/en/support/root-certificate/root-globalsign.php
