Maximum size of image file for attachments
I tried to upload 990MB png file as case attachements.
Accoriding to the on line Help, file attachments are restricted to 1 gigabyte in size.
So my expectation I can upload the png file as case attachements,
but when I tried it shows Pop up and say "Only file(s) upload supported".
I want to know the reason of this error are displayed and
what is the mzaximum size which we can upload as case attachements.
The PRPC version is 7.2.2.
According to documents
"You cannot attach a file larger than 25 megabytes to a work object. Similarly, this limit applies when using the Upload button on Rule-File-Text, Rule-File-Binary, and Rule-File-eForm rule forms, and with the Upload button on the Import Archive tool. You can enforce a higher or lower limit on your system with by changing the value for the Initialization/MaximumFileUploadSizeMB parameter in the prconfig.xml file. (The number of attachments you can associate with a single work object is not limited.)"
Basically you can use this:
<env name="Initialization/MaximumFileUploadSizeMB" value="nn" />
Check what is the limit set in your prconfig.xml or in DSS setting for this.
Also I tried uploading .png type it was successful for me.
Thank You.
