Wipro Limited
Last activity: 17 Jan 2017 9:23 EST
sax parse error: Content is not allowed in prolog in Pega 7.1.7ID
I am trying to connect to REST service and getting below error
com.pega.pegarules.pub.services.InboundMappingException: Caught unexpected exception mapping inbound data: Invalid clipboard stream detected in module com.pega.pegarules.data.internal.clipboard.XMLStream.newStream(String, StorageStream). Reason: sax parse error: Content is not allowed in prolog.
It is happening while i am mapping the response JSON to clipboard page ( Response_POST). If i try to map the response JSON to the text property (DefaultResponsePost in class structure mentioned below) on clipboard, I don't get this error and i can see valid JSON response in the text property.
Data structure is already in place as per the expected response.
Sample JSON Response :
{"TransactionData":{"ErrorMessages":[{"ErrorCode":"102","ErrorMessageDetail":"Your ID is not authorized.","Type":"BusinessRuleValidation"}]}}
Class Structure :
Comp-FW-AppFW-Int-EndPointA ( Connect REST Applies to this class )
- Response (Comp-FW-AppFW-Int-Response)
-DefaultResponsePost ( Text Property )
-Response_POST ( Comp-FW-AppFW-Data-ResponsePOST)
- ResponseID
- TransactionData (Page of Another Class)
Class Structure :
- ResponseID
- ErrorMessages ( Page List of different Class)
- ErrorCode (Property )
- ErrorMessageDetail ( Property )
- Type ( Property )
Connect REST Response Mapped as
Map To : Clipboard
Key : .Response.Response_POST
Hi Please help us with full stack trace of the error message to suggest relavent solution for the reported issue.
