SSN Masking Control
Does Pega has a control that can hold SSN.
When a user input SSN value, it should mask as XXX-XX-XXXX and it should save the actual value in the assosiated property.
I also wanted to use mouse over (Smart Lable) to show the last four digits of the input value.
***Updated by Moderator: Vidyaranjan. Removed user added Ask the Expert tag. Apologies for confusion, shouldn't have been an end-user option***
SSN masking display already discussed in some other topic, can you please check, are you able to tweak the code for your requirement
https://collaborate.pega.com/question/ssn-masking-control
