Last activity: 26 Jan 2017 19:54 EST
Requesting documentation on prconfig setting "initialization/allowauditlogging"
A partner that I work with is requesting documentation around the prconfig setting "initialization/allowauditlogging".
Apparently this was added for a client a few years ago, and enables internal engine logging. He's looking to understand how to setup the appenders to capture this log output.
Ben
Updated: 26 Jan 2017 19:54 EST
Hey all,
I found the following documentation, attached, hope this helps others!
Here are the results of running a PegaSample GeneralTask. I created it and then resolved it.
I used these prconfig options
<env name="initialization/audit/allowed" value="true"/>
<env name="initialization/audit/whitelist" value="PegaSample-Task BasicProcess;Work- Add"/>
Time |
Requestor |
Thread |
Application |
User |
Event |
Type |
Name |
Key |
Ruleset |
Version |
AuditCorrelation1 |
Hey all,
Time |
Requestor |
Thread |
Application |
User |
Event |
Type |
Name |
Key |
Ruleset |
Version |
AuditCorrelation1 |
AuditCorrelation2 |
2013-10-30 15:18:49,163 GMT |
H0BEB7F1BE74E4D34B674B7191C48FF58 |
TABTHREAD1 |
PegaRULES:07.10 |
Activity Start |
ACTIVITY |
Work- Add |
RULE-OBJ-ACTIVITY WORK- ADD #20130919T002508.278 GMT |
Pega-ProCom |
07-10-03 |
Test1 |
Test2 |
2013-10-30 15:18:50,410 GMT |
TABTHREAD1 |
PegaRULES:07.10 |
Flow |
Flow Start |
PegaSample-Task BasicProcess |
RULE-OBJ-FLOW PEGASAMPLE-TASK BASICPROCESS #20131009T095017.564 GMT |
Pega-AppDefinition |
07-10-03 |
Test1 |
Test2 |
2013-10-30 15:18:52,049 GMT |
TABTHREAD1 |
PegaRULES:07.10 |
Flow |
Flow Idle |
07-10-03 |
Test1 |
Test2 |
2013-10-30 15:19:33,982 GMT |
TABTHREAD1 |
PegaRULES:07.10 |
Activity End |
ACTIVITY |
Work- Add |
Pega-ProCom |
07-10-03 |
Test1 |
Test2 |
2013-10-30 15:19:57,168 GMT |
TABTHREAD1 |
PegaRULES:07.10 |
Flow |
Flow Resumed |
07-10-03 |
Test1 |
Test2 |
2013-10-30 15:19:57,684 GMT |
TABTHREAD1 |
PegaRULES:07.10 |
Flow |
Flow End |
07-10-03 |
Test1 |
Test2 |
Cheers,
Ben
Ben,
What version is this? I could not find this setting in both 7.1.9 and 7.2 code base.
Yeah Frank said the same thing
I'm checking with the partner to see what's up.
Hey all,
Time |
Requestor |
Thread |
Application |
User |
Event |
Type |
Name |
Key |
Ruleset |
Version |
AuditCorrelation1 |
Hey all,
Time |
Requestor |
Thread |
Application |
User |
Event |
Type |
Name |
Key |
Ruleset |
Version |
AuditCorrelation1 |
AuditCorrelation2 |
TABTHREAD1 |
PegaRULES:07.10 |
Activity Start |
ACTIVITY |
Work- Add |
Pega-ProCom |
07-10-03 |
Test1 |
Test2 |
TABTHREAD1 |
PegaRULES:07.10 |
Flow |
Flow Start |
07-10-03 |
Test1 |
Test2 |
TABTHREAD1 |
PegaRULES:07.10 |
Flow |
Flow Idle |
07-10-03 |
Test1 |
Test2 |
TABTHREAD1 |
PegaRULES:07.10 |
Activity End |
ACTIVITY |
Work- Add |
Pega-ProCom |
07-10-03 |
Test1 |
Test2 |
TABTHREAD1 |
PegaRULES:07.10 |
Flow |
Flow Resumed |
07-10-03 |
Test1 |
Test2 |
TABTHREAD1 |
PegaRULES:07.10 |
Flow |
Flow End |
07-10-03 |
Test1 |
Test2 |
Cheers,
Ben
