Scotiabank
Last activity: 23 Mar 2017 10:30 EDT
Can I create a tenant specific application from Multitenant administrator?
Hello
We are using a Multitenant application, the multitenant admin will provide an FW application as SaaS and tenants can override the default behavior if they want. Now there is another requirement that multitenant admin will create an implementation application for the tenants after creating a new tenant.
Now if I create an application using multitenant administrator, the application will be marked as 'shared' in database and tenants will not be able to make any changes in the application.
Is there any way to create a tenant specific application using multitenant administrator?
Sandeep
when you create a tenant, there is a setup activity where you can import RAP into a specific tenant. I know this is not what you want since tenant has already been created. But pega MT is designed with security in mind, the role to do that has to be tenant admin, not from the shared admin. BTW, what version of prpc are you using?
