Tata Consultancy Services
SA
Last activity: 27 May 2025 9:28 EDT
Pega Upgrade Issue from 8.8.3 to 24.1.3
We are trying to upgrade Pega platform from 8.8.3 to 24.1.3.
During upgrade we are facing issue with sql executions related to views , earlier we faced issue with Stored procedure and we executed upgrade with elevated DB user and stored procedure got executed successfully.
Now issue with views with the same elevated user. Please find the stack trace below, we are in k8s environment.
[java] Exception in thread "main" java.lang.RuntimeException: Error during execution of upgrade on platform oracledate using schemas SYSTEM, SYSTEM, SYSTEM
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.main(SchemaGenerator.java:1500)
[java] Caused by: com.pega.pegarules.data.ddl.DatabaseException: java.sql.SQLException: ORA-31603: object "MVIEW_EVALUATIONS" of type VIEW not found in schema "SYSTEM"
[java] ORA-06512: at "SYS.DBMS_METADATA", line 6731
[java] ORA-06512: at "SYS.DBMS_SYS_ERROR", line 105
[java] ORA-06512: at "SYS.DBMS_METADATA", line 6718
[java] ORA-06512: at "SYS.DBMS_METADATA", line 9734
[java] ORA-06512: at line 1
[java]
[java] at com.pega.pegarules.data.ddl.SchemaManager.<init>(SchemaManager.java:430)
[java] at com.pega.pegarules.data.ddl.SchemaManager.<init>(SchemaManager.java:471)
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.getSchemaManagerFromConnection(SchemaGenerator.java:249)
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.getSchemaManagerFromConnection(SchemaGenerator.java:225)
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.generateUpgradeDDL(SchemaGenerator.java:578)
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.main(SchemaGenerator.java:1371)
[java] Caused by: java.sql.SQLException: ORA-31603: object "MVIEW_EVALUATIONS" of type VIEW not found in schema "SYSTEM"
[java]
[java] at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:526)
[java] at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:462)
[java] at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:1104)
[java] at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:553)
[java] at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:269)
[java] at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:655)
[java] at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:270)
[java] at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:91)
[java] at oracle.jdbc.driver.T4CPreparedStatement.executeForRows(T4CPreparedStatement.java:970)
[java] at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1020)
[java] at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1176)
[java] at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3671)
[java] at oracle.jdbc.driver.T4CPreparedStatement.executeInternal(T4CPreparedStatement.java:1426)
[java] at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3718)
[java] at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1167)
[java] at com.pega.pegarules.data.ddl.JDBCIntrospector.readObjectBodies(JDBCIntrospector.java:2031)
[java] at com.pega.pegarules.data.ddl.JDBCIntrospector.readViews(JDBCIntrospector.java:498)
[java] at com.pega.pegarules.data.ddl.JDBCIntrospector.createDatabaseJaxbObjectByIntrospection(JDBCIntrospector.java:119)
[java] at com.pega.pegarules.data.ddl.SchemaManager.createDomDocumentFromDbIntrospection(SchemaManager.java:2041)
[java] at com.pega.pegarules.data.ddl.SchemaManager.<init>(SchemaManager.java:426)
[java] ... 5 more
[java] Caused by: Error : 31603, Position : 7, Sql = select dbms_metadata.get_ddl('VIEW',:1 ,:2 ) as def from dual, OriginalSql = select dbms_metadata.get_ddl('VIEW',?,?) as def from dual, Error Msg = ORA-31603: object "MVIEW_EVALUATIONS" of type VIEW not found in schema "SYSTEM"
[java]
[java] at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:530)
[java] ... 24 more
[java]
***Edited by Moderator Marije to add Support Case Details ; update capability tags***
The support ticket was resolved with the below explanation:
Here is our analysis:
User switched to "System" user instead of custom application user for Pega
The SYSTEM user will not be applicable in this case. You will need to adhere to the Upgrade Process as outlined in our documentation.
Please refer to the following link where you will need to create the necessary users and grant the required privileges for the upgrade:
https://docs.pega.com/bundle/platform/page/platform/install/db/k8s-configure-oracle-install.html#configure-oracle-user-permissions
Have you reviewed the ZDT upgrade guide prior to initiating the upgrade? https://github.com/pegasystems/pega-helm-charts/blob/master/docs/upgrading-pega-deployment-zero-downtime.md
Upon reviewing the YAML file, we noticed that the targetRulesSchema and targetDataSchema fields are not set, which are mandatory. User explained their plan was to do a in place upgrade with the existing schema that's the reason they didn't provide the new schema names.
Pega response: User current specification of the upgrade type as "zero-downtime" without setting the "targetRuleSchema" and "targetDataSchema" is leading to the upgrade failure.
For comprehensive instructions on the upgrade process, please refer to the following link: https://github.com/pegasystems/pega-helm-charts/blob/master/docs/upgrading-pega-deployment-zero-downtime.md.
Additionally, you will need to create the necessary users and assign the required privileges for the upgrade, as outlined here: https://docs.pega.com/bundle/platform/page/platform/install/db/k8s-configure-oracle-install.html#configure-oracle-user-permissions.
Please ensure that you follow all the recommendations above and rerun the upgrade, then inform us of the outcome.
Note: It is advisable to have a dedicated deployment user instead of using the "system" user.
An additional issue was encountered relating to index creation, script is trying to create a index which already exists in the existing data schema and i have verified it has been created in the new dataschema as well.
Pega response:
Support document addresses an issue related to Oracle databases : https://support.pega.com/support-doc/update-fails-ora-01451-ora-02429-ora-02443-and-ora-00955-sdr-301.
To resolve the problem, you should remove the indexes and primary key from the affected table. The upgrade process will reinstate them
Dropping these indexes and retrying the upgrade is successful
