Capgemini
Last activity: 28 Mar 2025 12:04 EDT
How to configure Local action on a embedded list in constellation
scenario: In my case type data model, I got embedded data (which is a list of a data object, say Product)
In the first assignment, I give user ability to build the list, this way he can do selection of few products.
From next assignment onwards, I want to show in a tab the list of selected products as a table with a hyperlink on product id.
when user click on this product id, it should open a local action that can fetch and show information about this product from an external system.
To meet this requirement, I could not find a way in OOTB to open a local action using a link.
In constellation gallery, I found Actionable button and I thought to use it to fulfil this need.
The challenge is it had a restriction to use pyGUID and when I tried to use it, its attempting to find a row with the given productID in the data object. In my case, the records are not present in Pega.
Did anyone solved similar requirements?
Thank you
@SateeshB6784 in your second instance, when you're showing the Product (externally sourced), it should be a data reference. You're loading data, so that should be a data reference (not embedded).
There's a lot of ins and outs to your question, so hard to nail it down 100%. For me, if you have a data reference:
I want to do this in embedded data then save back to the external SOR?
You might also be describing this. If so, more detailed instructions that might help:
