Mainframe Automation using Pega RPA v22
Hi Team,
Good day!!
I'm looking for videos, links or documentation to help me automating Mainframe (HOD) application using Pega V-22.
I'm getting an 'invalid session ID' error, error while integrating Mainframe, introgration form is not loading.
I've verified that the session ID is correctly set to 'A' in the HOD Application and that 'Auto-start HLLAPI' is also setted "Yes" in the emulator's settings, for Test Adapter application session is 'A'.
Please help me here.
Thanks in advance.
@PooranCJ In rereading your post, you may be starting your interrogation too early. With text applications, you need to launch the app first and then start interrogation. Make sure that if you are connecting to session A that it is up and running before you start interrogation.
