Chubb
Chubb
MX
Chubb
Posted: Feb 7, 2025
Last activity: Feb 27, 2025
Last activity: 27 Feb 2025 5:32 EST
we cannot run the app error "the role based authorization check failed for admin authz operation DynamicServiceManager
I asked our Generative AI tool what the error means: The role-based authorization check failed for admin-authz operation DynamicServieManager:set0bjectName:javax.management.ObjectName. The user UNAUTHENTICATED (unique ID: unauthenticated) was not granted any of the following required roles: administrator, operator.
This is its response:
The error indicates that the role-based authorization check has failed for the specified admin authorization operation. Specifically, it means that the user identified as 'UNAUTHENTICATED' does not have the necessary roles (administrator or operator) to perform the action related to 'DynamicServiceManager:setObjectName'. This typically occurs when a user attempts to access a resource or perform an operation without being properly authenticated or authorized, leading to insufficient permissions.
References: Working service account unable to access System Management Console- ADMN0022E error.
