How to get size of a specific page in bytes or KB using activity
Need to get size of a clipboard page using activity
To get the size of a specific page in bytes or KB using an activity in Pega, you can use the estimatePageDataSize
Java method. Here's a step-by-step guide:
Create a new Activity:
Add a Java Step:
Java
.Insert Java Code:
Use the following Java code to estimate the size of the page:
// Import necessary classes
import com.pega.pegarules.pub.clipboard.ClipboardPage;
import com.pega.pegarules.pub.clipboard.ClipboardProperty;
import com.pega.pegarules.pub.runtime.PublicAPI;
// Get the page you want to measure
ClipboardPage myPage = tools.getPage("YourPageName");
// Estimate the size of the page
long pageSize = tools.estimatePageDataSize(myPage);
// Convert size to KB
double pageSizeKB = pageSize / 1024.0;
// Log the size
oLog.infoForced("Page size in bytes: " + pageSize);
oLog.infoForced("Page size in KB: " + pageSizeKB);
Run the Activity:
Add a Java Step:
Java
.Insert Java Code:
// Log the size
Run the Activity:
This method will help you determine the size of a specific page in bytes and convert it to KB for easier readability
Hi Avinash , will try out the approach thank you for the response
Hello Avinash ,
I was trying to fetch the size of the page using below code , my page will initially will be in one of the parameters [Param.ClipboardPageName] of type page and mapping it into a string called ClipboardpageName. when trying to save the rule im getting an error as
Error :
The method estimatePageDataSize(String) is undefined for the type PublicAPI
Compile failed.
// Java Code
ParameterPage objParamPage = tools.getParameterPage();
String ClipboardPageName = objParamPage.getString("ClipboardPageName");
long size = tools.estimatePageDataSize(ClipboardPageName);
Is there any otherway to get size and i couldnt include import classes steps because its causing below issue
Syntax error on token "import", yield expected
