Issue
On logging in, the Constellation work portal fails to display the landing page and becomes unresponsive. The following errors are observed:
On-screen error:
ViewContainer
Failed to display content. Contact the application administrator.
Browser console error:
Error while Rendering the component undefined: TypeError: Cannot destructure property 'routeKey' of 'this.appRoutes[n]' as it is undefined.
Root cause
The 'D_pzBuiltOnAppRoutingTable' data page, which resolves and combines routing table entries, returns stale, cached data. As a result, when the Constellation portal attempts to load, it receives an outdated routing table that lacks the required route for the landing page. This leads to the application attempting to access a non-existent 'routeKey' property, causing the 'Cannot destructure property routeKey' error.
Solution
Update to Pega Platform 24.2.2, see Pega Platform 24.2.2 patch resolved issues.
OR
Workaround
As a workaround, apply the following hotfixes:
HFix-C1743 on Pega Platform 24.1.2
HFix-C2254 on Pega Platform 24.1.3
HFix-C1833 on Pega Platform 24.2.0
HFix-C1184 on Pega Platform 24.2.1
The hotfix alone might not fix the issue if the routing table does not contain a valid route. In such scenarios, follow the below steps in sequence until the issue no longer persists:
Save the application rule.
Clear the browser cache and storage.
Regenerate the application routing table
Navigate to the 'Advanced' section of the application rule.
Click the 'Generate routing table' button.
Unlock a ruleset; otherwise, the button will remain disabled.
