Here are answers to some frequently asked questions. See also My Support Portal Frequently Asked Questions.
How are my phone calls secured?
What information should I provide with my support ticket?
Working with Pega Support: Screenshares, access to environments
How do I engage with a support team?
When should I engage with a support team?
What are the criteria for reopening a support ticket?
Escalating a support ticket
What is a Client Advisory case?
Related content
Main document
Pega continuously works to implement security controls to protect your data. As such, we have expanded controls for clients who call into our regional support contact centers.
Callers inquiring about a specific problem or requesting client-specific information will be required to go through a multi-factor verification process of two steps.
- Step 1: Identification – We check your account affiliation.
- Step 2: Authentication – We verify that the phone number you are calling from matches the number we have in our records.
Only verified My Support Portal users will be able to interact with the support team.
To avoid disappointment, ensure that both your account affiliation and personal profile information are up to date.
Account Administrators (formerly Support Administrators)
(Also known as Support Contact Administrator)
If you are an Account Administrator, review the user affiliations for your account and ensure that you have the right resources assigned. To help you refer to Managing users & permissions at Pega.
All other My Support Portal users
Check your profile in My Pega to ensure that you have the correct phone number listed in your Pega profile.
When you create a support ticket in My Support Portal, you complete a form that guides you through the process. As you complete the form, the system prompts you to provide relevant information based on the basic details of your case.
Be prepared to include the following information:
- Clearly state the business impact of the situation or request, considering the effect that it is having on application users, development teams, and project milestones.
- Provide a description of the situation, including the steps to replicate it.
- Provide relevant supporting information. Here are some examples:
- Screen shots and error snippets that illustrate the problem, preferably in a Word document with the steps to reproduce the problem.
- Verbose Runtime Log Capture.
- Log files, for example, Pega logs, application server logs, utility-specific logs.
- Relevant information from PDC, for example: PDC tenant and system name, where PDC is integrated.
- Results of performance tools like Performance Analyzer (PAL) and Performance Profiler, including Assessing system performance stability in PDC.
- Tracer results.
- JVM settings.
- System settings (prconfig.xml file settings or Dynamic System Settings, DSS) PegaRULES, PegaALERT, PegaCLUSTER logs from all node(s) where the error is observed.
- For on-premises clients:
- Application Server type \ version, Database type \ version.
- Garbage Collection (GC) logs, heap dumps, list of JVM parameters during memory issues.
- For Queue Processors & data flow related issues - Partition report, life cycle events, screenshots of all tabs of the data flow run id.
- Kafka diagnostics or Kafka server logs for embedded stream node related issues. PegaRULES, PegaALERT logs from any other nodes where error related to stream \ Kafka is observed.
- Cassandra logs, PegaRULES, PegaALERT logs from DDS nodes for embedded Cassandra related issues. PegaRULES, PegaALERT logs from any other nodes where error related to Cassandra is observed.
- Provide any root cause or diagnostic analysis that you have completed prior to creating the support ticket.
- Link to any relevant content from your self-service investigations. See Support self-service offerings.
Providing this information when you create your support ticket expedites investigation, root cause analysis, and resolution.
During the investigation, the support team guides you in collecting any additional information that might be needed to advance the support ticket to its resolution.
Working with Pega Support: screen shares, access to environments
Protecting your data and complying to global compliance standards is essential to Pega. During an investigation GCS may require access to your environment to further the troubleshooting process. To maintain the safety and the security of your system please follow these guidelines:
- Create a Pega Support specific access by setting appropriate access controls for Pega support. Do not use credentials of named users such as [email protected] instead use a generic credential such as Proprietary information hidden.
- Do not share the credentials through Public Pulse posts. Please share passwords via telephone only. Work with your GCS engineer to verify access live, during the phone call, to avoid ambiguity.
- Limit the access for Pega Support to a specific period. The access must be revoked once it is no longer required.
- Do not share Admin access or Root access, and other such access types that gives Pega Support more control than required to investigate the issue.
- Share access to the specific applications that has the issue. GCS can always request access to more apps if required.
- Document access requests provided to Pega (with access type, reasons, and period of access provide) for audit purpose.
As a Pega client, you use My Support Portal or My Pega Cloud to create support tickets related to your use of Pega on-premises products, Pega Cloud® services, or client-managed cloud environments.
Before you create a support ticket, take a look at the following questions and answers. For more details, see Creating a support ticket.
What kind of support tickets can I submit?
How can I submit a ticket for a problem I'm having with Pega software?
How can I initiate a change in my Pega Cloud environment?
You can report an or an , or you can request a .
See this Question and its Answer in My Support Portal Frequently Asked Questions, the section Submitting tickets.
See also Creating a support ticket.
Pega support teams are expert in Pega products and services, their operating environments, and the third-party products upon which Pega products and services are built.
As a Pega client, you can engage with a support team under a variety of scenarios for your product issues:
- Product or service issue
- Functionality problem
- Environment or configuration issue
- Unexpected changes in performance
- Planned update or production go–live
- Other issues or events that result in significant business impact
As a Pega client, you can engage with a support team under a variety of scenarios for your Pega cloud environments:
- Incidents
- Outages
- Security and compliance needs
- Pega Cloud Service Requests and Change Requests
- Provisioning Requests
- Network Configuration Changes
For more information, see Creating a support ticket.
This answer identifies the criteria for reopening an Incident or an Issue (INC), a Cloud Assistance (SR), or Root Cause Analysis (RCA) support ticket.
From within My Support Portal, the Support Case Reopen feature allows you to reopen a Support ticket that was resolved within the past 4 business days. If the Support ticket was resolved more than 4 business days ago, but within the last 3 months, you can clone the ticket.
Reopen Reasons:
| Reason | Description |
| Additional Information needed | To ask a question about a previously resolved problem |
| Explanation issue | The explanation provided for the problem does not hold true in all scenarios. |
| Hotfix problem | The hotfix provided for the problem has not completely solved the problem or has introduced a new problem. |
| Local change issue | The local change provided for the problem has not completely solved the problem or has introduced a new problem |
| Recurrence of problem | The problem stopped occurring before it was fully understood; however, it has since reoccurred. |
Additional points to note:
- Severity 1 Support tickets cannot be reopened.
- Where a Support ticket has been resolved with the resolution status No-Response, it cannot be reopened.
- A Support ticket can only be reopened once.
- Where a Cloned ticket is created it will be linked to the original ticket in the References tab
Also see How can I reopen a resolved ticket? in My Support Portal Frequently Asked Questions, the section Submitting tickets.
If you have concerns about the progress of your ticket, see: Escalating support tickets.
Our communication policy is outlined in Pega Support Technical Communications. The Client Advisory support case forms part of this policy.
Also, see related questions in the Submitting tickets section of My Support Portal Frequently Asked Questions.
The Client Advisory (CAD) case is a case type introduced by Pega to facilitate direct communication with you, our clients. This case type is created by Pega engineers and used to share important messages from Pega with you.
We use the CAD case to share the following types of information:
- Contact Maintenance
- Pega Cloud
- Product
- Security
- Support Policy Change
- Multi-Client Incident (MCI)
- Other important information
- Cloud data storage utilization
Depending on the type and urgency of the Client Advisory, here is how it works and what to expect.
Cloud Data Storage Utilization
Email notices
Action required
No action required
Pulse availability
Client Advisory case closure
This type of Client advisory is utilized specifically for Pega Cloud accounts only.
We monitor your Pega cloud environments and issue client advisories to help you manage your Cloud data storage effectively.
- An initial client advisory is sent when your Pega cloud environment hits 75% of your data storage capacity.
- A further client advisory is sent when your Pega cloud environment hits 90% of your data storage capacity. Note: additional charges could be applied if you exceed your date storage entitlement.
Each Cloud data storage utilization client advisory references a specific Pega Cloud environment and / or project. Notifications are sent to both cloud operations specialists and cloud deployment specialists.
Email notices
When a Client Advisory is issued, an email message is sent to all My Support Portal users for your account or to specific users, based on their role, for example, Cloud Deployment Specialists, Support Administrators, and Security Contacts. All users can view the CAD case in My Support Portal, even if they did not receive an email notice about the CAD case.
Action required
The Client Advisory might require you to take some action, for example, install an urgent security hotfix. After you complete the action, you can close the CAD case yourself: On the CAD case, scroll to the Resolution types section and select one of the options displayed. Then click .
No action required
The Client Advisory might provide important information that requires no immediate action from you other than communicating the information throughout your organization. An example of this type of informational advisory is notice of a support policy change. If the Client Advisory is informational only and requires no action from you, the CAD case closes automatically after a specified time.
Pulse availability
Pulse availability in a CAD case depends on the nature of the Client Advisory.
For some CAD cases, Pulse is available for you to raise questions or discuss any issues you may have with the Pega support team.
For other CAD cases, Pulse is not available because the CAD is placed in an unmonitored queue. When Pulse is not available in a CAD case, you can ask questions, and report concerns by creating a support ticket. The Pega support team will respond to your needs in your support ticket.
Client advisory case closure
Pega takes into account different factors to determine when a CAD will close. For example, generally CAD cases are closed 30 days after the date sent for all client advisory types except those related to Security. These are closed once the Security issue is publicly posted to the Support Center and Trust site, typically 30-90 days after the CAD is sent.
Related content
Main document
