Starting October 1, 2023, Pega Mobile Build Service will stop building selected older versions of the Pega Mobile Client™.
Affected versions
Pega Infinity Mobile Client 8.0.0 to 8.7.1, inclusive
Impact
If you are using Pega Mobile Client with standard settings, this event does not affect you. No action is needed.
If you are using Pega Mobile Client and forcing a build on older versions with .pyHCBuildVersion (Pega 8.1 or earlier versions) or ‘Other’ channel (Pega 8.2 or later versions), you will see the following error message after the attempted build:
Selected version of Pega Mobile Client is not available.
Suggested Approach
To prevent or recover from the error message, choose the approach for the Pega Platform version that you are running.
In , the Advanced tab, for the option Stop using ‘Other’ building channel, use either the default channel or the ‘legacy’ channel.
