Issue
Field-level error messages do not display in the Questionnaire case type, preventing users from identifying the specific fields which have errors.
Symptoms and Impact
Users are unable to determine which fields trigger error messages on pages with many questions, causing confusion and difficulty in error resolution.
Steps to reproduce
- In Pega Admin Studio, Create a Questionnaire case type
- Add fields to Questionnaire
- In case type settings, create a validation rule for the fields added in the Questionnaire
- Run the Questionnaire case type and trigger validations.
Observe page level error messages display but not field level errors.
Root Cause
This is an expected product behavior where we see page level errors and not field level errors in the Questionnaire case type.
Solution
This issue has been identified as a product limitation that requires a platform enhancement.
Issues are prioritized based on impact, severity, and capacity. The specific release for the fix has not yet been determined. This section will be updated with release details when the fix for this issue is available.
