Attaching a file triggers field level auditing when no changes to selected properties occured
We have a case type with field level auditing enabled with a few values on an embedded page tracked.
The auditing process works as expected when saving or submitting an assignment.
The issue occurs when a user uploads an attachment, it triggers the field level auditing and creates FLAudit records for each tracked field where the old value is always blank even if the property had a value and no changes occurred on it.
Has anyone experienced this issue or have any suggestions?
Thanks in advance,
Mack Bryan
