Issue
Enabling the ‘auto-save’ option for forms on a ‘Case Type’ within a password-protected application does not automatically save the forms.
Steps to reproduce
Navigate to Dev Studio > Application > Definition > Security tab.
In the 'Security' tab, check ‘Require password to update application’, and click ‘Update password’ to set the new one.
Click Save to apply the changes to the application Rule
Override the ‘pyEnableAssignmentFormAutoSaveFlag’ When Rule in the application ruleset and configure it to always return ‘true.’
In the ‘Settings’ tab of the ‘Case Type’, select the checkbox labeled ‘Auto-save assignment form changes regularly when a user isn’t typing.’
Root Cause
This error occurs due to a limitation in Pega’s code or Rules.
Solution
An enhancement request has been raised for this issue but has not yet been assigned to a specific release.
Workaround
In the interim, temporarily disable password protection on the application Rule to enable the ‘auto-save’ option using the ‘Case Type’ settings. This step is only required when selecting the checkbox using the ‘Case Type’ settings. Once 'auto-save' is enabled, password protection can be re-enabled on the application Rule.
