Write file to local disk
The Connect-File method is designed to create files on application server. There is no option to specify a local disk file path (on C: drive). I know this is for security consideration. But we have a use case to exchange data with a legacy thick client application, which only supports passing input params via a locally stored file. The legacy application UI doesn't have field display for some of the input param. So passing the data from UI via RDA will fall short also. Is there a viable way to take data on clipboard and write file to local storage?
