Work History Table and pyLinkedObject and pyLinkedObjectClass properties
While I was implementing inbound email work processing I ran into an issue.
I observed a DB commit error execution of Activity Work- pyCreateAndManageWorkFromEmail…
2016-10-19 18:39:04,311 [ EMAIL-Thread-130] [ STANDARD] [ ] [ NPI:01.01.01] (nageWorkFromEmail.Work_.Action) ERROR EMAIL.ProcessEmailReply.Listener|from([email protected])|sub(Email Appr)|Email|NPIEmail|ABI-NAZ-CA-NPI-Work-NPPA|CreatepyStartCase|AAFC326E7BBEFEF374AFD79FA2F416873 - Error in commit()
com.pega.pegarules.pub.database.BadTableMappingException: Database-BadTableMapping-TooManyProperties History-ABI-NAZ-CA-NPI-Work pegadata.pc_History_ABI_NAZ_CA_NPI_Work PegaDATA pyLinkedObjectClass , pyLinkedObject
at com.pega.pegarules.data.internal.access.PageDatabaseMapperImpl.fillInSaveStatementWithoutStream(PageDatabaseMapperImpl.java:1650)
at com.pega.pegarules.data.internal.access.Saver.getStatementWithPrepValues(Saver.java:1707)
at com.pega.pegarules.data.internal.access.Saver.addBatch(Saver.java:975)
at com.pega.pegarules.data.internal.access.Saver.saveInstance(Saver.java:866)
at com.pega.pegarules.data.internal.access.Saver.saveInstance(Saver.java:777)
at com.pega.pegarules.data.internal.access.Committer.performOps(Committer.java:243)
at com.pega.pegarules.data.internal.access.DatabaseImpl.attemptToProcessUpdates(DatabaseImpl.java:2751)
at com.pega.pegarules.data.internal.access.DatabaseImpl.processUpdates(DatabaseImpl.java:2400)
at com.pega.pegarules.data.internal.access.DatabaseImpl.commit(DatabaseImpl.java:2127)
at com.pegarules.generated.activity.ra_action_pycreateandmanageworkfromemail_3a45813c4a6a1bf69258af9a1b387721.step42_circum0(ra_action_pycreateandmanageworkfromemail_3a45813c4a6a1bf69258af9a1b387721.java:3500)
at com.pegarules.generated.activity.ra_action_pycreateandmanageworkfromemail_3a45813c4a6a1bf69258af9a1b387721.perform(ra_action_pycreateandmanageworkfromemail_3a45813c4a6a1bf69258af9a1b387721.java:838)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3510)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:466)
at com.pega.pegarules.integration.engine.internal.services.ServiceAPI.runActivities(ServiceAPI.java:1896)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:390)
at sun.reflect.GeneratedMethodAccessor123.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1277)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1015)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:848)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:331)
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.handleStandardRequest(EmailListener.java:3671)
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.handleRequestContents(EmailListener.java:4033)
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.handleRequest(EmailListener.java:3901)
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.emailProcess(EmailListener.java:3493)
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.oneIteration(EmailListener.java:2816)
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.run_(EmailListener.java:2676)
at com.pega.pegarules.integration.engine.internal.services.listener.ServiceListenerBaseImpl.run(ServiceListenerBaseImpl.java:454)
at java.lang.Thread.run(Thread.java:745)
The class and DB table mention above (History-ABI-NAZ-CA-NPI-Work & pegadata.pc_History_ABI_NAZ_CA_NPI_Work) were generated through Case Designer (add case type).
I opened an SR and I was advised to expose these columns (pyLinkedObjectClass , pyLinkedObject) on the work history table.
Just out of curiousity I have the following questions:
- What do these properties (pyLinkedObjectClass , pyLinkedObject) do exactly?
- And because these properties being exposed is a dependency for the OOTB activity (Work- pyCreateAndManageWorkFromEmail) why isn't it exposed at the time when they are generated (by Pega)?
- I don't see these properties mentioned in the ER diagram below. Is this ER diagram outdated?
Thanks in advance!!
***Updated by Moderator: Vidyaranjan| Tagged SRexists***
