Sberbank
UA
Last activity: 26 Aug 2020 8:41 EDT
Why a question about ECS has such answer?
There is a question in the Senior System Architect Essentials:
You have a requirement to create an email correspondence that can be reused by other applications. In which two layers of the Enterprise Class Structure could you apply the email correspondence rule? (Choose Two)
There are the answers:
- Implementation
- Division
- Organization
- Framework
Division and Organization are correct, but I don't understand, why the Division is there.
The question doesn't specify that the rule could be reused only in an application of a specific division.
So, I assume, that it should be available into all applications. And according to this logic the most reasonable
answers are: Organisation and Framework. Or there should be three answers: Organisation, Division and Framework.
Am I right?
***Moderator Edit: Vidyaranjan | Moved from PSC to Academy***
if you speak conceptually it is parallel, I agree to it.
But if you create a Div by going to advance option while creating application you will see Org-Div-FW
Now I understood why the answer is like that.
Suppose these are your threeclass structure
Org-FW-IMPL
Org-Div-FW-IMPL
Org-Div-IMPL
Now if you see you may not always have a framework layer to work with. Also as mentioned in CSA
Org-FW-IMPL
Org-Div-FW-IMPL
Org-Div-IMPL
Now a Division Layer can have multiple framework layer and finally Framework layer will have Implementation.
So in this scenario the best two are Organization and Division layer.
Hope this helps.
Thank You.
