why clear filtering clears sorting on Report
We are using a DPage with Report definition as source and we have enabled filters and sorting option on the column. (DPage is requestor level and has reload per interaction enabled)
for eg - Case ID
During run time in a section - we get the list populated.
1. first filter by Case ID.
2. once filtered we apply sort which sorts the filtered list
3. finally when we clear the filter by clicking on the clear filter option the filter gets cleared as expected but it also clears the sort, However, the sort icon remains as it is.
Ideally the sort icon should appear and the list should be sorted, which in our case isn't happening.
