Infosys Ltd
Last activity: 31 Aug 2020 8:18 EDT
Where can we configure functions for Run Script action
I have a requirement to use run script on button click which eventually calls a activity for SAML token and the activity does show html to configure the logic. There are some existing places in UI where we are using run script and a function and in tracer i can only see the SAML token activity . Where can i find out the function.
***Edited by Moderator: Pallavi to change category from General to Product, update platform capability tags***
Check which harness is used and go to the scripts and styles tab of Harness , You can find many js files and one of which should contain your function. Mostly it can be Perform Harness.
