JP
Last activity: 29 May 2016 23:20 EDT
when user B tries to open his/her assignment, PRPC says the work is still locked and under modification by user A
Our customer (on 7.1.9 / PegaCloud production environment) is experiencing the similar issue - not sure it's the same.
After user A finishes his assignment & submits it, PRPC routes it to user B then.
The issue is that when user B tries to open his/her assignment, PRPC says the work is still locked and under modification by user A.
Is this symptom potentially the same as what's explained above, if yes, does user B need to wait for 2 hours max (or 30 sec max?)
*Default locking is selected as case lock configuration.
Message was edited by: Marissa Rogers - branched to its own thread, added category
if user A is still viewing the assignment in the perform harness, that's why it is still locked, and user A should get in the habit of closing the window if they expect user B to handle the work, to make sure it doesn't stay locked.
However, I'm a little puzzled about why user A is still viewing the assignment in the perform harness after routing it to user B. I would think the normal behavior after such a routing would be for user A to be viewing the assignment in the review harness. You should check what's going on with your flow-harness settings. /Eric
