When do we write script in section ?
Hi ,
In what type of requirements we write script in section.
Regards
Pavani
Hi ,
Regards
Pavani
Hi ,
For example if you want the script to work only for that section itself than we use script in that section.
Hi Any example please
Can someone please clarify me on this
Hi Pavani
What is your motivation behind asking this question? Perhaps sharing that might enable us to help you better.
Bhuvana.
I think maybe you need to flip the question on its head and answer it that way. I cannot think of a generic "requirement" which would require that you write hand coded scripts within your section.
Usually this approach or solution would come about organically to solve a specific business requirement when OOTB solutions are not available. This is similar to when you need to hand code your own controls when the OOTB ones available do not meet your needs.
Placing such a script would localize the inclusion of your code to where it is relevant and needed, as opposed to including it somewhere globally where it might be included unnecessarily.
