When Condition Run
When condtion has 3 inputs , I added three parameters and clicked on Actions-> Run. No matter what i try this condition always results in false.
How to run a when condition, is this the correct way
Could you please share the screenshots of the when rule.
Did you pass the correct parameters which return the when values as true?
Attached Screenshots
Hi
You are not using those parameters in the when rule and it will always be false :)
You have defined the parameters in the When rule but you are not using them. It's the reason that you are seeing the result as always false even if you pass different parameters.
To use parameters in when rule after defining them, you can use it as Param.AplicationType.
This is probably what you want...
