Wells Fargo
Last activity: 18 Dec 2024 5:17 EST
What is the significance of the rule- pyRoutingtable (Rule-UI-Routing)
Automatic rule-pyroutingtable is getting created automatically when correspondence rule is created. can anyone suggests the significance/background of that rule? Thank you.
Updated: 24 Jun 2024 8:37 EDT
@Rakeshr7 - Routing Table has information about whenever any DX API or semantic url hits the server this routing table mapping holds which path to go to get the data/payload required for that call. This data will be used to get the views on to the UI.
Thank you.
@Rakeshr7 I found refernces to this table in the below documentation:
Enabling Constellation applications for registration
@Sam Alexander is this a Constellation-specific functionality?
Thank you.
Rakesh kumar Mohammad Ravoof
TCS
I see pyRoutingTable for Theme-Cosmos. and Cosmos React, is there any difference between the two.
@BalajiC7 - Yes completely different and these pyRoutingTables wont work in hybrid mode of constellation application.
Thank you.
Krupa Vara Prasad Babu Pulavarthi
TCS
Do we use any Routing Table for Theme Cosmos , as Theme Cosmos does not use Pega DX API. If so where could we see it
Capgemini
@Priyanka Boga - Hello Priyanka, I want to send a link in an email for a user to open the case in portal. I think routing table will be helpful for that in constellation app.
For example, the below link should open the case in WebPortal in computerland app for send-emails case but its opening dev studio.
https://dev.pega.com/prweb/PRAuth/app/computerland/send-emails/S-19006?portal=WebPortal
Routing entry in pyRouting rule:
"send-emails/{workID}": {
"routeKey": "openWorkByHandle",
"payload": {
"caseID": "OK5NFJ-Computer-Work {workID}",
"caseName": "send-emails",
"caseClassName": "OK5NFJ-Computer-Work-SendEmail",
"page": "pyDetails",
"workID": "{workID}"
@SateeshB6784 this question was about the significance of pyRoutingtable and the post is 6 months old and has an accepted answer.
Your question does not seem relevant to the original post.
Please Ask a New Question.
NAB
@Rakeshr7 This is basically c11n related feature and related to DX APIs.
This table used for mapping of data . It is storage of the data.
Whenver view gets called this used pyrouting table.
This is not related to any routing typ information table like infinity.
Rakesh kumar
