What impact does lowering the Cache Keystore Setting to 60 from 3600 have?
Does anyone know what impact lowering the Cache Keystore Setting to 60 from 3600 has?
My client is experiencing issues with this setting. Initially, it was set to the default value of 3600 seconds, but users started encountering errors. They lowered it to 60 seconds, which fixed the problem. Now, client is concerned if there is any performance impact by reducing this value.
Below article suggests that decreasing these values will result in less memory usage, but it will also reduce processing power. Does this imply that the server's performance will be affected? Any insights or guidance on this matter would be greatly appreciated.
https://docs-previous.pega.com/security/87/changing-default-keystore-caching-settings
