What is the correct syntax when using a parameterised Field Value?
hi all,
I'm trying to use a parameterised field value in my build, but I can't seem to get the correct syntax to pass in the parameters (the Help just says use a \t delimiter but doesn't actually give you the syntax).
My field value text is:
but I'm not sure how to reference is from my label control. I've tried the following (just trying to get the first parameter working) but it's just interpreted as a string literal:
Any pointers much appriciated!
Phil.
