Last activity: 29 Feb 2016 11:48 EST
Validation fail on Cancel button
Kindly refer to the below PDN link
My question is
Does making this change in UserWorkForm not have any other implications? I've checked this in 7.1.7 and still this issue exists.
As per my analysis onClick of cancel button we are calling Review action . If we analyse the code a little further: inside Submit function(pega_ui_doc_submit) the strAction which is being passed as an argument upon click of Cancel button has an attribute
"skipClientValidations" which is set as true. This attribute might have been set(as name suggests) to surpass the client side validations.
So instead of below if block in Submit function
if ( !strAction == "" && (pega.u.d.bClientValidforReviewAction || !(oActionURL.get("HarnessPurpose") && oActionURL.get("HarnessPurpose") == "Review")))
it should have been
My question is
it should have been
if ((oActionURL.get("skipClientValidations")=="" || !(oActionURL.get("skipClientValidations"))) &&!strAction == "" && (pega.u.d.bClientValidforReviewAction || !(oActionURL.get("HarnessPurpose") && oActionURL.get("HarnessPurpose") == "Review"))). Tried this change by making a private edit of "pega_ui_doc_submit" and it worked fine.
My intention is adding pega.u.d.bClientValidforReviewAction = false; may have implications else where.
So what I think is there should have been an extra check in the if block of Submit function. Please do correct me if I'm wrong.
