Using SendSimpleEmail
Are there any issues if I use SendSimpleEmail from an Activity. I need to send a correspondence object as well in the email. However SendSimpleEmail is giving error in higher environment. It is working fine in Dev environment but failing in test with below error.
Tried calling CorrNew from the activity as an alternative , however the email is not generated at all.
Error:
Error:
Exception at 20180419T020000.673 GMT: com.pega.pegarules.pub.clipboard.InvalidReferenceException: The reference <code block> is not valid. Reason: FUAInstance-NullMyStepPage at com.pegarules.generated.activity.ra_action_sendsimpleemail_1514f1485bc5212645ab15b16c859210.step14_circum0(ra_action_sendsimpleemail_1514f1485bc5212645ab15b16c859210.java:1586) at com.pegarules.generated.activity.ra_action_sendsimpleemail_1514f1485bc5212645ab15b16c859210.perform(ra_action_sendsimpleemail_1514f1485bc5212645ab15b16c859210.java:322) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3553) at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10711) at com.pegarules.generated.activity.ra_action_runccrejobstatuslatest_c2e894acf90ca827b5fd5ad6bea8ade0.step15_circum0(ra_action_runccrejobstatuslatest_c2e894acf90ca827b5fd5ad6bea8ade0.java:1549) at com.pegarules.generated.activity.ra_action_runccrejobstatuslatest_c2e894acf90ca827b5fd5ad6bea8ade0.perform(ra_action_runccrejobstatuslatest_c2e894acf90ca827b5fd5ad6bea8ade0.java:352) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3553) at com.pega.pegarules.session.internal.async.agent.QueueProcessor.runActivity(QueueProcessor.java:749) at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:618) at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:1000) at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1286) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1034) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:916) at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:707) at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:991) at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:532) at java.lang.Thread.run(Thread.java:745)
