Using DSS for setting thresholds - all works but connectors?
I have reconfigured the threshoulds for one environment, I am able to configure all but the connector thresholds in Dynamic System Settings. However if I configure this setting in prconfig it works. Is this a known "feature" ? I'm using Pega 7.2.
These configurations works in DSS:
prconfig/alerts/browser/interactiontimethreshold/warnms
prconfig/alerts/database/operationTimeThreshold/default
prconfig/alerts/database/packagingTime/warnMs/default
These dont work:
prconfig/alerts/connector/inboundMappingTime/threshold/default=nn
prconfig/alerts/connector/totalRequestTime/enabled=true
prconfig/alerts/connector/outboundMappingTime/threshold/default=nn
prconfig/alerts/connector/outboundMappingTime/enabled=true
prconfig/alerts/connector/totalRequestTime/threshold/default=nn
prconfig/alerts/connector/clientResponseTime/threshold/default=nn
prconfig/alerts/connector/clientResponseTime/enabled=true
(Owning ruleset: Pega-Engine for all above)
...But they do work if I set them in prconfig.xml, for example totalRequestTime:
<env name=" alerts/connectors/totalRequestTime/enabled" value="true" />
<env name=" alerts/connectors/totalRequestTime/threshold" value="800" />
