URLs and Atmosphere framework parameters
Our customer performance testing team are using menu items URLs in order to simulate click on the screens.
Recently they have noticed some changes on Atmosphere framework parameters for menu items under the "New" link of the interaction portal :
- Atmosphere-Transport=long-polling to Atmosphere-Transport=polling
- atmo-protocol=true
Are these parameter autogenerated each time the menu or the section are updated ?
Are they linked to the parameter on the prconfig.xml ( Dynamic System Setting, Owning Ruleset: Pega-EngineSetting Purpose: prconfig/server-push/transport/defaultValue) ?
And in general could we guarantee that such URLs will not change after each delivery ?
Note: The used version of Pega platform and CS is 7.3.1
Ahmed
Ahmed
Hello Ahmed,
Find answer to below query:
Query: Are they linked to the parameter on the prconfig.xml ( Dynamic System Setting, Owning Ruleset: Pega-EngineSetting Purpose: prconfig/server-push/transport/defaultValue) ?
Answer:
server-push/enabled -Accepts: true,false If false is chosen, then push server is not initialized during node startup.
server-push/transport-
Rincy
