Unit Testing RPA Without Dependence on Application
I'm working on setting up Continuous Integration and Delivery for RPA development and am wondering about best practices for unit testing RPA code. It would be best to not depend on the live application for a number of reasons:
- The unit test project might have to be deployed to a separate machine with an active user session in order to run it, rather than being run right on the build server.
- Test case data cannot be guaranteed not to change
- There's no way to guarantee that the application will not go into an unavailable state
- Running negative tests (such as wait-for-create timeouts) would either be impossible or make the unit test runs take a long time (as opposed to simulating timeouts without having to wait the full time)
The way I know to handle these scenarios is to use dependency injection and inject mocks for all the controls of the application, so that the RPA code doesn't know (and doesn't care) whether it has the real application (interrogations) or a fake one. This would have to be a custom, in-house build. However, I wanted to ask here to see if there is some built-in way to handle this, and if someone has experience with this before going ahead with that solution. Also, if we use custom code to achieve this kind of testability, would Pega refuse to support our RPA code?
