Unable to retrieve data from PRPC Personal Edition 7.2.2 to Pega Robotics studio
I am trying to integrate Pega 7.2.2 application from robotic studio 8.0. I have done required configuration as suggested in PDN article. See below URL.
https://docs.pega.com/pega-rpa/how-do-i-configure-robotic-automation-pega-platform-applications
I followed below steps for integration:
1. Done Configuration settings as suggested in PDN article link above.
2. Created test solution in robotic studio.
3. Added robotic activity and configured its properties Name, Class, Fields ("Fields" property is not configured).
However, I am not able configure Fields property of robot activity. An error message is displayed while accessing collection.
Actual error message while accessing of Fields property of robot activity component:
Error requesting data from Pega.
(Above URL generated with error message in output window of robotic studio while accessing Fields property)
Output from browser of above URL:
"pxObjClass":"Pega-API-Data"
,"errors":[
"ID":"Pega_API_022"
,"message":"Use of TLS/SSL is required"
,"pxObjClass":"Pega-API-Error"
It looks like TLS issue. Pega also recommends to use TLS 1.2 while accessing APIs. So can anyone know How to enforce TLS 1.2 using robotic studio/.net framework to access Pega API? What could be the possible solution for this error?
All relevant screens shots are attached in the post.
Thanks in Advance.
Nikunj
