Unable to optimize a property embedded in data- class page that is embedded in a work- class
Hi all,
I am attempting to optimize a property in a data- class page that is embedded within a work- class. I am trying to have that property optimized within the work- class, not the data- class. The only way that I can do this so far that I can tell is to select the property from within the embedded data page(inside the work- class) in the app explorer and select optimize property there – the issue is that some of these data-classes are so large that I cannot see the property in the left side panel bar and am forced to click “new window”. However, when I select the property here and try to optimize it there, it forces me to only optimize the property in the data- class, instead of the work- class where we need it to be optimized in order to get rid of the guardrail warnings. We used to be able to use pzBulkOptimization in the past in order to do this, but in Pega 8.1.3, we cannot search this activity and run it. Was it deleted? Also - I traced what does happen during a optimization using the wizard, and found two other activities, pzAlterTable and pzOptimizeAProperty, but i cannot search these either - is this expected behavior? If so, what is the workaround for optimizing the data- property in the work- class?
Thank you - anything that you can do to help would be much appreciated. Please see the attached document for repro steps.
