Hcl Technologies
Last activity: 17 Aug 2018 9:32 EDT
Unable to Import/Install Selenium Starter Kit Component from PDN exchange
Hi Team,
We have 7.3.1 version installed and we couldn't Import(wizard)/Install (Manage Components) Selenium Starter Kit Component which we downloaded from PDN exchange.
PFA Snapshots.
Vamsi.
Have you checked compatibility of "Selenium Starter Kit Component"? at your place with Pega 7.3.1.
In the screen-shot shared, there is an error which is indicating that the kit seems to be incompatible with your environment.
Refer the installation guide of kit and also share the link from where you have downloaded the kit?
Hcl Technologies
We have downloaded it from "https://community.pega.com/marketplace/components/selenium-starter-kit". It is mentioned in the link that the component is compatible for both 7.4 and 7.3.1. Do we need to verify any other details. There are no supporting documents for this component related to install/config. Please share if any.
Vamsi.
Intel Corporation
Hi Team,
Even I am not able to find any documentation on Setting up the test frameworks and running the tests step-by-step instructions in PDN. Can someone please help?
Navneet
The documentations for downloading, setting up and running the Selenium tests are in the same page (scroll down to the bottom) - https://community.pega.com/marketplace/components/selenium-starter-kit
Also, you should download the Selenium Starter Kit outside of Pega - it looks like you are downloading the Selenium Starter Kit into Pega. Please see the documentation for proper installation.
Hcl Technologies
HI Belam,
Yes, have found 2 links under support section. However accessing url "https://community1.pega.com/documents/selenium-starter-kit-running-ootb-sales-automation-ui-smoke-tests" returns 404. Please let me know if there is an alternate link for that.
Vamsi.
Hi Vamsi,
The link to the document was fixed here: https://community.pega.com/marketplace/components/selenium-starter-kit
Please try accessing this URL and let us know: https://community1.pega.com/documents/selenium-starter-kit-running-ootb-sales-automation-ui-tests-your-cicd-pipeline
Thank you!
Hcl Technologies
HI Lochan,
HI Lochan,
I guess the broken link (Running OOTB Sales Automation UI Smoke Tests) is not fixed. Rather it was just pointed to "Running OOTB Sales Automation UI tests in your CICD pipeline" link. But both these topics are different. As mentioned in "Running OOTB Sales Automation UI tests in your CICD pipeline" link, we need to go through "Running OOTB Sales Automation UI Tests" doc for setting up the test projects and running the UI tests locally.
Please provide us with the link where Setting up UI tests and execution process is explained.
Vamsi.
Hcl Technologies
Hi Lochan,
The document you have provided is specific to Windows and it is mentioned in the document that there are other OS specific documentation for the same. Can you please provide me the link for implementing the same in Linux.
Vamsi.
Hcl Technologies
Hi Lochan,
It seems this plugin is specific to Pega Customer Relationship Management product. How can we make use of it for testing general PRPC applications.
Vamsi.
Hcl Technologies
Hi Lochan,
Any update on my query.
Vamsi.
Hcl Technologies
Can someone help me on this.
The Moderation Team is reaching out to Subject Matter Experts on this for you. Hang in there and thank you for updating your post that you're still looking for help!
Thanks!
Afni
I am having the same issue. I have 7.3.1 as well. When i select to download the starter kit, it gets to 31.0 out of 48.4 MB and then it just freezes. Thanks.
Hi @DianeS90,
I had my team check here and they didn't have any difficulty downloading the starter kit. Have you tried again? Were you successful?
Thank you,
