Unable to fill pool: exception
We are not able to connect to the pega (7.3) application as we are getting the below highlighted error.
Recently we moved the database from stack 7 to stack 8 and with the new user we are able to connect to oracle client.
However Jboss connection is getting failed with below error for one of our environment.
Previously we have done the same change for other environment and its working fine.
Please provide suggestions.
2022-06-07 00:04:22,635 WARN [org.jboss.jca.core.connectionmanager.pool.strategy.OnePool] (JCA PoolFiller) IJ000610: Unable to fill pool: java:/jdbc/AdminPegaRULES: javax.resource.ResourceException: IJ031084: Unable to create connection
at org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:345)
at org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.getLocalManagedConnection(LocalManagedConnectionFactory.java:352)
at org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createManagedConnection(LocalManagedConnectionFactory.java:287)
at org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.createConnectionEventListener(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:1322)
at org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.fillTo(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:1142)
at org.jboss.jca.core.connectionmanager.pool.mcp.PoolFiller.run(PoolFiller.java:97)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.sql.SQLRecoverableException: IO Error: The Network Adapter could not establish the connection
at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:774)
at oracle.jdbc.driver.PhysicalConnection.connect(PhysicalConnection.java:688)
at oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDriverExtension.java:39)
at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:691)
at org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:321)
... 6 more
Caused by: oracle.net.ns.NetException: The Network Adapter could not establish the connection
2022-06-07 00:08:37,099 WARN [org.jboss.jca.core.connectionmanager.pool.strategy.OnePool] (JCA PoolFiller) IJ000610: Unable to fill pool: java:/jdbc/PegaRULES: javax.resource.ResourceException: IJ031084: Unable to create connection
***Edited by Moderator Marije to add Support Case Details ***
